J3 on revision D needs to be configured, with out the baud divider connected there is no tx/rx clock to the 6850
Building the KLyball 600D
Re: Building the KLyball 600D
Bill, can you post the file, so there is no confusion? Thanks!BillO wrote:I got the video working. It was the character generator. I found a different file, burned it, tried it and we're all good now!
@KLyball - Thanks Grant for posting that. I finally figured it out after looking through the schematic for a while. Too long, really. Ahhh...
Is that new (600D) Superboard II doc available on-line somewhere? It would be nice to have a copy.
@Jeff. The character generator file that worked for me is attached below.
Thx Grant!
My 600D is up and running at 100%! Thanks everyone for your assistance on this!
Now, here's more good news. My memory expansion board functions 100% too on this mainboard. So that project can now continue.
BTW, what baud rates do you folks use and what do you use for end of line and character delays for text transfers?
9600 no delays
A question for anyone that has experience with both the 600B and the 600D.
On my 600D, the first column of video seems to start 3 columns over from where the same first column does on the 600B. Like below:
Is this normal?
600B:
D/C/W/M?
600D:
D/C/W/M?
A quick question for anyone with working 600D: If the board is in 48-character mode, and you press the reset button/Break key, does it switch back to 24-character mode? I seem to remember that it does, but I'm not sure.
If I recall correctly, 48 char mode will survive a reset, but not a cold start.
