OSIWeb.org wish list :-)
Help preserve OSI history!! Please check here to see if you have wanted items, or post your wanted items here
Re: OSIWeb.org wish list :-)
Post by Steve Gray » Thu May 04, 2017 5:23 pm
dave wrote:
Thu May 04, 2017 3:17 pm
Yes, that's the Mittendorf board. Thanks for the nice photos. If someone were to trace out the schematic, I could write something up about it, since I did a hi-res mod for my C2 that I think would be similar enough.
I imagine this circuit borrows signals from the video timing chain to sequence addresses to 1 port of a 2-port RAM; a data latch; and a shift register whose output can be OR'd with the OSI video shift register.
It would be great to reproduce one of these. Any chance of working with one of you to get one of these boards scanned?
As far as I know there's no connection to existing video circuitry. The video output is independent so you need a separate monitor, or switcher, which was a little inconvenient so I never really did much with mine. It should be trivial to re-create this board and/or update it to take a single ram chip. My desoldering skills are a little rusty, but I'd be willing to remove all the components and scan the PCB if that would help you recreate the schematic.
djones60
Post by djones60 » Thu May 04, 2017 6:28 pm
Actually on my board it did connect to the original video circuit. That was what the smaller ribbon cable was for. On the end of it was a small PCB with solder tabs. From these were some 30ga wires that ran to various points on the Superboard. Unfortunately over the years they had all come lose and I don't remember where exactly they connected. So the Superboard just used one common monitor.
Working OSI 600 Rev D with metal case
second 600 Rev D with PIA/Memory board and metal case, working status unknown
Mittendorf board for the Superboard - not working
djones60
Post by djones60 » Thu May 04, 2017 6:35 pm
I still have a few more boxes of stuff from those days to go through. So, I'm still hoping to find the manual for the board. I did find a nice stash of Micro magazines, C User group news letters, Dr Dobbs, bunch of cassettes, etc.
Post by Steve Gray » Thu May 04, 2017 6:46 pm
Dave,
I just scanned and uploaded "TinyCompiler1.3.pdf" to your drop box. Not sure if it's the same version you mention you're looking for.
Post by Steve Gray » Thu May 04, 2017 6:50 pm
Interesting. I used mine on my C4P and 100% sure I never connected anything to the video board... I guess instructions would be handy. I'm really puzzled why my instructions are missing.. all my OSI stuff was packed in a single box.
djones60
Post by djones60 » Thu May 04, 2017 7:16 pm
Must be nice. Some of mine got left at home, some followed me to Purdue, and there is some stuff a friend gave me along with his Superboard. So I have at least three stashes of stuff and maybe more still a mom's house. If I get time tonight, I'll dig through the boxes with some of the old college stuff.
Post by Steve Gray » Fri May 05, 2017 2:07 pm
Dave,
I scanned and uploaded "The Bookkeeper's Bookkeeper" brochure to your dropbox folder.
Post by dave » Thu May 11, 2017 3:27 pm
Dave,
Steve, that's awesome! I think that's the latest published version. Peek(65) volume 8 no. 3 lists a modified v1.1 to run on OS65D and support disk operations. This is the first copy of v1.3 I've seen. I suppose the tight numbering starting at line 12 is intended to enforce the default limit of 10 source code lines.
Thanks!
Post by dave » Thu May 11, 2017 3:28 pm
Dave,
Thanks!
