Building an OSI 542 Rev C Keyboard
Re: Building an OSI 542 Rev C Keyboard
I have been busy.
I have completed the keyboard.
gekaufman wrote: Thu Nov 08, 2018 7:54 pm Finished up the keyboard last night - Hopefully will have time to test this weekend, and anxiously awaiting the Keycaps.
- Gary
Gary, post some pics of your finished keyboard 😃
Does it work?
Not yet tested. 🤪
I finally got around to testing the completed keyboard and it works (Mostly)!
What does not work is the BREAK/RESET circuit. While it DOES automatically reset the system upon power up, it does NOT STOP resetting the system! I put my scope on the Reset wire that goes to the 502 and confirmed the pulse.
Reset Pulse.jpg (1.08 MiB) Viewed 10423 times
I am not familiar with how the circuit works, so I am asking the online experts here what to check next.
I found the problem with the Break key circuit. There is an incorrect trace on the PCB.
I solved it by lifting pin 8 of U1H and then connecting +5V to the U1H pin 8 OF THE SOCKET, not the lifted pin.
I can see how this happened. When Grant was laying out the PCB based on photos I sent him, I sent him a diagram incorrectly showed the trace going to pin 8. I incorrectly assumed that the power would go to opposite corners as is traditional.
Here is the photo I provided to Grant a few years back... I added the orange line today to show the trace under the socket.
The 74LS75 breaks from tradition of placing the power and ground on opposite corners of the chip.
+5V is designated on Pin 5 and Gnd is on Pin 12.
Here is a Note File that describes the fix.
PCB IMPORTANT NOTE.pdf
(309.37 KiB) Downloaded 797 times
And now my keyboard is working perfectly!
EDIT: Originally, I thought Grant made the mistake on the incorrect trace. I came across a photo of a diagram that I sent to him with the mistake clearly made by me. I have edited the above to reflect this new info.
One final note... the MX keys feel awesome!
/J
gekaufman
Post by gekaufman »
Jeff -
Thanks for posting the fix. I ran into the same problem with a continuous reset and found that a 4.7K resistor across the .001uf cap let the circuit work - but clearly this was not the proper repair.
- Gary
Here is my Parts List. I use the spreadsheet to track my build progress.
542C Keyboard Parts List.xlsx.zip
(11.31 KiB) Downloaded 602 times
keith_r25
Post by keith_r25 »
Thanks for the assembled keyboard Jeff!
I was using the Parts Layout.pdf at the beginning of this post for parts placement and D1-D4 are shown reversed. I should have used your Keyboard Part List.pdf pic as they are show correct.
Thanks again,
Keith
