- rom.jpg (94.62 KiB) Viewed 2769 times
- proto1.jpg (121.38 KiB) Viewed 2769 times
- proto2.jpg (100.49 KiB) Viewed 2769 times
A = ASC
B = TAN
C = SIN
D = SGN
E = RETURN
F = FRE
G = LEN
H = VAL
I = STR$
J = STOP
K = CONT
L = LOAD
M = LOG
N = ATN
O = DEF
P = PEEK
Q = NEXT
R = RND
S = SAVE
T = RESTORE
U = CHR$
V = COS
W = STEP
X = LET
Y = READ
Z = DIM
0 = POKE
1 = FOR
2 = THEN
3 = GOSUB
4 = GOTO
5 = INPUT
6 = DATA
7 = LEFT$
8 = MID$
9 = RIGHT$
: = USR
- = INT
RUB = LIST
RETURN = RUN
LF = REM
SPACE = PRINT
> = NOT
< = AND
/ = TAB(
; = END
. = EXP
, = SQR
? = SPC(
+ = CLEAR
ESC = cancel keyword mode
According to the directory listing created by Mark there is a copy of COMPDOS 1.3 on the rabble7 disk. It is one of the files that doesn't appear to have any errors.RedskullDC wrote: ↑Wed Aug 03, 2022 6:20 am The group also released a disk operating system called "COMP-DOS", though I haven't been able to find any info.
The KAOS newsletters are not yet scanned in their entirety at preservation quality but I have had a quick look through the surviving issues that I have access to.RedskullDC wrote: ↑Wed Aug 03, 2022 6:20 am That DABUG rom image up on osiweb came from a RevD Superboard II that came my way quite some years back.
From what I have been able to glean, "David Anear" was the hardware guy at the "Victorian 6502 Users Group" in the early 80's.
They had a regular newsletter called "KAOS, for those who got smart", which lasted at least until late 1983.
The group supported OSI, SYM, KIM, AIM, UK101, APPLE and ORANGE users.
