Any sources for the space bar hardware for the Klyball 600?
Thanks!
- Gary
Klyball 600 Space Bar Hardware
Re: Klyball 600 Space Bar Hardware
Hi Gary, what key switches did you use on the Klyball 600? Also, where did you source your keycaps?
I got my switches from Ebay, and the keycaps from Dave.
The spacebar hardware was tough to find, but I eventually found a set that fit, I think from Amazon.
