Hi everybody,
I am a proud SBII owner from Seville, Spain. Last week I tried to connect my TFT VGA monitor to my SBII using a Video to VGA converter. The result was a rolling image, so no vsync signal problem.
The converter is this: https://www.amazon.es/mondpalast-S-Vide ... onvertidor
Has anyone conneted SBII to a VGA monitor with success?
I attach a video showing the issue.
Thanks in advance!
No vertical sync signal when trying to use VGA monitor with my SBII
Re: No vertical sync signal when trying to use VGA monitor with my SBII
Oye como va,
Welcome to the forum. No, this never worked for me - not sync properly and poor video. You can get a good picture with old LCD TV with AV input tho.
Hello!
I didn't read your comment, no notify alert in my inbox
So I could see my SBII output on an old LCD via VIDEO IN signal?
I tried it on a Samsung CRT Video IN with success!
So I will buy an used LCD TV and will try it!
Thanks!
Thanks!
