A new document for the build and construction of the Glitch Works 502 board.
GlassTTY
Post by GlassTTY »
I am in the process of building a Glitch Works 502 CPU board to use as a standalone board using a serial terminal for keyboard and display, it's turned into quite a challenge so thought I had better document the process.
The document is linked below and was originally intended for my own use but figured it was maybe worth sharing in case it helps others.
It's simply a draft document at present but, I'll update the document as I work my way through the build.
John
https://github.com/johnnewcombe/OSI_UK1 ... er/OSI/502
John Newcombe:
Replica 600 Rev D, 8K, CEGMON.
Replica 610 Rev B, 16k, Teac 55B with Data separator D-13.
Replica 400.
Replica 502.
UK101, CEGMON.
